Having trouble locating a replacement universal joint for a 1992 4WD F150.
The universal joint im trying to find is on the rear of the rear drive shaft. All the ones the parts stores around here have are to wide. They measure 3.622 from outside of cap to outside of cap. They are held in with snap rings and you can't get the snap rings in place because the U joint is too wide. I measure from inside the groove where the snap rings go to the other side and its about 3.5 inches.
Even tried the local Ford dealership and they didn't come up with anything. I thought this would be an easy fix.
