- Joined
- May 10, 2025
- Messages
- 46
This is the first UOA of my recently purchased 1992 Crown victoria. The milage is low, the exterior and interior are in incredible shape for the age, and the vehicle has some mechanical issues, this is usually how I like to purchase my vehicles. The story from the seller is that the original owner parked it about 10 years ago when she was no longer able to drive, the vehicle sat inside a warehouse, and was recently revived after a long period of sitting, by way of a fuel pump and tank, possibly a wash, and apparently nothing else. I drove the vehicle home about an hour running on 7 cylinders at best. The oil change sticker in the windshield is from a Ford dealership, from 2010, possibly the last oil change. The oil was pretty bad visibly, and the filter had visible sludge. I will post filter cut photos in the respective forum. The analysis results are fairly horrific, but after an oil change immediately after coming home, and new spark plugs and wires to fix the misfire, the engine is running smooth and quiet. With luck, I hope to have escaped catastrophic failure. It will be interesting to see how analysis pans out from here. The vehicle will receive several changes of bulk conventional to flush out the junk over the next few hundred to thousand miles.
