Happy Saturday BITOG!
I'm getting into tearing into my 1990-91 23' Fleetwood motor home with a Ford 460 and Econoline cut-away front end. Gas gauge shows empty. Tested at the gauge and sender unit, found 75 ohms to ground at both. Leads me to believe the sending unit is bad, or, more likely, the float got gas-logged and sank to the bottom.
Have the tank hanging down, and am fighting with the quick-connects. They curve as they go into the flexible lines and don't give me enough room to start both halves of my quick connect tool. I've also tried stabbing in there with a pick, pushing the lines toward the sending unit, etc. Not budging.
Does anyone know what they used for flex fuel lines? I've got a foam rubber outer layer, braided steel, and then unknown. If it's rubber I may wind up cutting and splicing the lines back together. I've done it with vinyl as well but really hate doing it as they go poorly. May try a sharkbite style fitting instead of barbed, if I have to.
I'd like to reuse as much of the sender as possible. Does anyone know a source for just a float, preferably plastic? I have one, or a couple, of small engine carb floats I could safety wire in place, but that's kludgy even for myself, LOL.
Does anyone know how the sending unit seals to the tank? One-time-use goo, gasket, O-ring? I like O-rings.
Additional notes: 75 ohms empty was a Ford spec that, per my research, ended in 1986-87. I am assuming I have this old-style because motor homes are conservative and use older stuff, longer. That being said, I don't want to deal with buying new parts for this thing by guessing it's an E350 van. Fuel tank is a pleasant rectangle, almost like a fuel cell, aft of the rear axle, boxed in by the Ford frame. I "guess" it might be a Ford part, but it could be an aftermarket with the Ford sending unit flange, or it could be a real bastard child since there's an extra nipple for the fuel line for the generator. VIN shows 1990 but title shows 1991.
