I'm trying to fix a braking issue in my 1965 Rambler American 330.
The brake pedal is soft. Not spongy, it goes to the floor. Once you're at the floor and you push harder on it, it will start to slow down. If you just press the pedal down really fast it will lock up the wheels.
The front brakes are totally rebuilt with new wheel cylinders. While bleeding the rear brakes first (decided to try even though it is a seperate system), there is no air in the back lines at all, the brake fluid comes out fine through the bleeder screw like normal.
While bleeding either side on the front brakes, the fluid just barely dribbles out while cracking the bleeder screw. If I have the master cylinder cap off while bleeding , it shoots out like a water fountain just as the pedal is pushed down the first 1/8 of an inch. Nothing on the return stroke.
Any ideas short of bench bleeding the master cylinder or possibly replacing it? There isn't any leaks anywhere, not even under the dash.
