Originally Posted by Hombre909
You are under new car warranty correct? Toyota specs that engine for 0W-20. 0W-40 might give you a problem if you have a warranty claim on the engine. JMHO
Or on the other hand I bet there isn't one statement in either the owner's manual nor the warranty booklet that says deviating from the recommended grade will void the warranty. In fact doesn't it say:
"An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions"
Owner just has to state they thought the loads were extreme.
Correct on the wording in the manual, plus Toyota specifies up to 20w50 elsewhere in the world for this very same engine, so 0w-40 is a good choice.
