On older engines, 15w40 works great, but can be used on newer stuff too, especially if you are working your engine hard in hot weather. PCMO 10w30 SM starburst oil is not the ideal oil for most air-cooled engines in hot weather/heavy use. Kohler does specify 10w30, but it is a heavier 10w30 with more antiwear adds and higher viscosity than current SM 10w30 starburst oils- more like a 10w30 HDEO. They use 10w30 due to the hydraulic lifters in their engines. I've seen brand new vertical crankshaft engines smoke on startup after sitting a while. I like to use synthetic oil in my engines because I work them hard. My current favorites are the dual rated Amsoil 10w30/SAE 30 "commercial" oil for gas engines under warranty that require a 30 weight, and Schaeffers 5W-40 for gas or diesel engines. I run both of these year round with no worries and very little if any smoke or consumption. My engines range from new to 30+ years old in the mowers, riders, generators, and tillers. Granted you will have to go to some effort to find/get these oils since they are not often found in the retail market. Regular old 15w40, such as Delo, Delvac, and Rotella, is my second choice and works very well, too. Schaeffers and Amsoil have other oils that work well in these types of engines, too.
