- Joined
- Oct 30, 2021
- Messages
- 727
This wouldn’t have had happen if he used that new Fram Endurance filter.
Combined with that stellar Puro media & pleat spacing, it's a miracle they last 5-7500 miles.I think the problem is with the high bypass in cold climates, perhaps because the bypass activation pressure is so high it causes a rapid drop in differential pressure, shuts again cause a rapid spike in pressure on the inlet side again, which rapidly opens the bypass but then it bleeds pressure quickly and shuts and then the cycle repeats and the repeated compressions and decompression are ripping the media apart.
Media has some grit in the bottom of the pleats but I wouldn't say its excessiveThis is an issue with either bypass, weak media support, or both. Either by too wide media spacing or not enough backing media support (Wire backed) etc. When the pressure goes as high as the bypass PSI it takes out the weakest link in the process. However, this bad I wouldn't be surprised if there was bypass not opening when required. It has 20k intervals written on the side & lower efficiency so this filter shouldn't have torn. Was the media real griddy/dirty/carbon?
Please explain what is wrong with Mobil engine oils? Please explain and provide facts.I believe it. mobil's filters and oil are a joke. It's why ill use orange cans before Mobil 1 filters.
The filter tore. It should handle 10k. I pushed a ancient tough guard to 20k plus before.Maybe the engine can't handle the 16K interval. I wouldn't go over 10K. How good the filter is, is irrelevant if the engine is the culprit. Get a used oil analysis at the 10K mark.
This was my thinking as well. I've pulled oil filters off equipment that were in use for a decade, and the media stood up to the abuse.The filter tore. It should handle 10k. I pushed a ancient tough guard to 20k plus before.
The owner has taken uoa which has brought him to 16k interval. I collected sample for him and he can decide with uoa what interval he wants to use next.Maybe the engine can't handle the 16K interval. I wouldn't go over 10K. How good the filter is, is irrelevant if the engine is the culprit. Get a used oil analysis at the 10K mark.
Note that the Titaniums are switching over to non-wire backed media, as the Ultras did. Bring a good flashlight and verify if it has wire backing through the center tube.I am less concerned of the engine having a mechanical problem and will likely switch out the current m1 212A for a wire backed titanium or endurance at some point this interval ...
Explain to me how their oil is a joke?, I hope a certain youtuber didn't get in your head.I believe it. mobil's filters and oil are a joke. It's why ill use orange cans before Mobil 1 filters.
Mobil doesn't make oil filters, they are produced by the same pair of companies that produce all the other filters. We've seen tears on many filters from across the spectrum, the only filters we've never seen tears with are the synthetic media ones like the OG Ultra, EaO, RP...etc.I believe it. mobil's filters and oil are a joke. It's why ill use orange cans before Mobil 1 filters.
But that's a filter with the standard ~8-14psi bypass not the ~16-28psi used on newer GM engines. A PH10063 or PH10064 used is a cold climate is a better comparison.A used oil analysis will show if the oil change interval needs to be changed, but regardless the filter is the issue here, not any of the other factors. There is a post a few lines up from this one currently of a cheap Champ WP2835 that took 16,000 miles of abuse and looked much better.
