15W 40 synthetic blend?
Rockville, VA
I have a John Deere 717A Z-Trak that specifies a 15W 40 synthetic blend oil, SG or better, for the hydraulic oil. Other than Amsoil or the Deere oil, is there any other compatible oil readily available at the store?
Shell Rotella-T 15w40 or any off the shelf heavy-duty engine oil 15w40 works well in those pump & wheel motor setups.
Joel
Schaeffers makes an excellent 15W-40 blend that is priced right as well. Call or PM "salesrep" (Mark) for excellent service. He is the site sponsor here for Schaeffers. Their full syn 5W-40 would work well, too.
Ok, now I see where you specified readily available at the store. There are probably some local Schaeffers reps in your area that you could look up online or call the main office. Otherwise I would just use some straight Rotella 5W-40 synthetic which would work great year round.
Castrol also makes a 15w40 blend, in Canada, its around $17 bucks a jug at wallys.
