12 Challenger 392, Mobil 1 0w40, ~6k miles
Texas
Did another spot-check on my 392, this was sampled back in September at about 26k miles on the engine. Filter was a Royal Purple synthetic. The first UOA on record (the 6/28/13 column) was with Pennzoil Ultra 0w40. The other two are Mobil 1 0w40.
Merry Christmas!
Great filtration. All trends look consistent with copper trending down.
Looks like dodge has a winner with the 392.
It's a sexy cubic inch number too.
Merry Christmas!
Nice, thanks. That is the current fill in the Shelby and will be for a few more as I deplete my 0w40 Mobil 1 stash.
Merry Christmas!
I just got an Mobil 1 stash. Got 7000 miles left to go on my Amsoil load first though in the truck.
Magnum
How us the vehicle operated.
What I'm asking is are you driving it pretty hard or are they easy miles,or something in between.
Thanks
Interesting about the Cu levels. Yours is going the right way. If the Cu comes from bearings, you would expect to have much higher levels of tin and lead in your history if the bearings were wearing into their happy spots.
Cu is a backing metal for bearings, it is covered with tin / lead overlay, so bearing wear would exhibit high tin & lead before the Cu got onto the UOA. Unless I have my head up somewhere dark?
Many oil coolers are copper construction, and after fabrication in mass produced engines, they are likely not ultrasonic cleaned before being placed in service. So Cu particles break free and get into the oil.
Aluminum (and occasionally silver) are also used as bearing-backing materials.
I was also thinking of perhaps oil cooler, but I don't know the app. Seems more plausible than bearing wear in terms of likelihood.
In the case of coolers, the ones that have Cu exposed surfaces, the initial installation will not have loose particles ~ this would be checked ~ trust me on this, I've worked in auto industry for over 20 years. Besides, the oil filter will catch particles, so these will not be part of the UOA.
Having said that, the exposed copper surfaces do react with the oil on the first fill and then form an oxide that stops further exposure.
I think there might be another source for the Cu, perhaps it is assembly lube /anti seize that is flushing out?
Originally Posted By: Doug Hillary
Hi,
With the copper and iron where it's at, I'd be looking for another oil.
Why??
Hello Doug
This post is a typical post from this member. If you look at his posts you'll see a trend develop.
Don't expect an answer that will satisfy. It'll just be nonsense.
Merry Christmas Doug.
The copper in Hemis (as in GM LSx engines) is pretty typical. They all do it, and it always trends down. Copper tends to leach into oil even from non-wearing surfaces in the oil flow path.
Everyone gets worried about copper because its the middle metal in tri-metal engine bearings. But as others have noted, before you even GET to the copper in tri-metal bearings, you have to have worn through all the babbitt (lead/zinc) overlay, and there's no lead at all showing. High copper with low lead is just never going to be a sign of a bearing issue.
And furthermore- I'm not even sure many modern engines even uses tri-metal bearings. Aluminum bearings were the norm in the 90s, and may still be.
Hi,
Why??
Because whoever is behind that username has a long history of taking any and every opportunity to recommend something other than a Mobil product for no other reason than that its a Mobil product. Just ignore.
I am.
Not sure if troll.
