11 Traverse Water pump
The Rockies
I get coolant leaks from below where the water pump is after short trips (~1 mile one way). When it's driven on extended trips it's dry as a bone. No leaking whatsoever even after it's sat for a few days. It went two months without leaking and then leaked again when a couple short trips happened again. Replace the water pump?
Yes, replace it!
Water pumps are one of the few things that actually give you a warning before they fail, so take advantage of that
Rock Auto carries the actual OE water pump for your Traverse
Probably a seal starting to go out. When warm expands just enough but those short cooler trips allow it to leak out a little and not dry from short trip.
Not to hard. Hardest part is getting the pulley off/on. Pump only has 6 bolts holding it on
Water pumps were a weak point on the earlier Traverse, Enclave, and Acadia models (Saturn Outlook also) My new at the time 2010 went bad after only 2 years. GM extended the warranty on them for 10 years/120000 miles BUT I think only through the 2010 model year. Check with a dealer to find out for sure and read Post#2 of this link for more information.
GM Extended Water Pump Warranty
You can change it going through the wheel well if I recall. Just check some of the Traverse/Enclave/Acadia forums for more information.
Thanks for the comments/advice everyone. I'll get the pump ordered. I'll likely do the thermostat too while I'm at it.
Sadly it looks like mine doesn't fall under the extended warranty.
