Originally Posted By: ARCOgraphite
I don't recall if this year engine has the roller cam with GM's version of "rhoades-style" fast bleed down lifter. If so the bleed down rate will be wrong with sae40 and you'll loose some low end torque and fuel economy.
If that was the case you'd lose significant power just running it in the winter. Viscosity change with temperature on a given grade is more than the difference between an xX-30 and an xW-40 at 100C.
Bingo, so many old wives tales here on BITOG it's sometimes like walking through a minefield...
Its about performance when at OP temp . All FE will suffer during cold/warmup. This illogical argument would make all multigrades KV100 spec essentially meaningless then.
You don't get what I'm saying, I'm not talking about warm-up or cold starts. My argument isn't illogical at all, you positing that GM uses some funky style viscosity sensitive lifter is what is illogical here.
Ambient temperature has an effect on oil temperature on an exposed pan application without a coolant/oil heat exchanger. And even with a heat exchanger, based on my experience with the M5, that effect is still present, just not as significant.
On a 30C day, let us say that oil temperature gets up to 100C.
M1 5w30: 11.0 cSt
M1 10w-40: 14.71 cSt
On a 25C day, let us say that the oil temperature gets up to 95C.
M1 5w30: 12.23 cSt
On a 20C day, let us say that the oil temperature gets up to 90C.
M1 5w30: 13.68 cSt
On a 15C day, let us say that the oil temperature gets up to 85C.
M1 5w30: 15.38 cSt
You following yet?
So, on our 15C day, the 5w30 actually has a higher KV than the 10w-40 does on the 30C day. Why? Because viscosity correlates with temperature! And since oil temperature has a relationship with ambient, that engine spends much of its time operating with an oil that is heavier than a 10w-40 at 100C. So for many months of the year, when the ambient temperature is cooler, that engine is in effect, running a heavier lubricant due to lower oil temperatures.
If what you posit is true, those lifters would be "malfunctioning due to improper bleed down rates" for half the bloody year! Do you honestly expect anybody to believe that GM is so inept that they'd design something like that? I know I don't.
