10w30 or 5w30
Virginia
Is it acceptable to run 10w30 synthetic in a vehicle that calls for 5w30?
I'm planning on running Synpower in my Direct Injected GM SUV. The book calls for 5w30, but the 10w30 seems to be a stronger oil. It appears these DI engines beat up on oil.
I live in VA. The winters are on the mild side.
Thoughts?
Only the battery will notice the difference!
I use the 10-30 often, only notice a tad in the Fall if I don't get the Winter fill in.
Less viscosity improver=more robust oil....10W is a very fluid state and the synthetics will work as they say...in most enviroments!
Use what belongs in there.. Unless you know more than the peoplr that designed the engine and if thats the case please come to my engine shop for a job...
5w30 flows quicker in most all situations
If it's a 3.6 DI like I am thinking it might be, then stick with 5w30. My buddy works at a GMC dealer and has done many timing chains on those 3.6s.
At least under warranty stick with 5w30.
i cannot see how the use of a 10w over 5w in *most* climates except canada could POSSIBLY affect ANY mechanical issue. cmon people. that truck would take 20w-50 down here.
Sorry, didn't want to imply mechanical failure. I was just stating a known problem with timing chains. Such that a dealer can fault the customer making them 100% liable to pay for repairs. Under warranty do what is recommended. That is all I was trying to say.
Valv. Australia recommends 10w30.
I would think a synthetic 10w30 (or even a synthetic 0w30 or 5w30) would out-perform a 5w30 conventional in both hot and cold extremes.
i get ya. does the manual give a chart vs temperature or ONLY the 5w30 recommendation?
I know most GM vehicles list 10w30 as "okay" above a certain degree I think 20 or 30. But it says right next to it in most cases that 5w30 is preferred.
At engine operating temperatures, both oils should be the same viscosity. The difference should be in the ambient temperatures, which is far different in say Michigan than in south Florida. I don't see how a 10W in a mild climate would hurt anything when compared to a 5W in a colder climate. In coastal SC, the temperature rarely gets to freezing at night during the winter, and is usually 50 to 60 F during the day. What on earth would a 10W harm more so than a 5W at 20 below in the northern US?
Mark
The manual does not have the typical chart that dispalys different oil weights at different temps. It only says 5W30. I have owned many vehicles and everyone of them had a chart in the manual except this new GM.
I don't think that VII breakdown is a problem nowadays.
Fuel dilution from Di systems that were not perfected before being marketed is another story.
I had a mitsubishi that reccomended 5w30 and i decided 10/30 would be fine in my moderate climate too....i spun a rod bearing in that one.
Personally, i don't know why anyone would run 10w/x in any engine anywhere after all the research i've done since then. Most damage will occur at startup and low vis is best at any temp for quick circulation...imho
