Originally Posted By: dnewton3
Regardless of grade, the oil film you are interested in is not going to be present after sitting for long periods of time. Once the oil drains down, it all sits in the pan, except for what may be trapped in the system by the ADBV. That's the bad news.
I guess that you've never pulled much apart...you end up covered in oil.The pistons and rings are full of oil, the bearings are full of oil.
There are capillary spaces that don't "all drain back to the sump"...and they provide a lot of lubrication in the first seconds of operation.
Heck, the oil residence time in the ring belt area is whole tens of seconds in a hot operation engine...that's virtually forever.
The good news is that oil retention really does not matter. It is a poorly understood phenomenon that the actual protective layer upon immediate start up is NOT, and I repeat NOT, the oil film boundary layer from oil pressure.
Well said...oil pressure doesn't lubricate anything.
There is no "oil film boundary layer" from oil pressure.
There are two common misconceptions, firstly that pressure lubricates, and secondly that flow lubricates.
when parts are moving, the differential velocity, the converging gaps, and the viscosity provide the hydrodynamic oil wedge (film) that keep the parts apart.
Rather, it is the tribo-chemical barrier of oxidized chemicals/elements that is developed along the surfaces that prevents metal-to-metal contact. Yes, once the engine oil pressure is up, the hydro-dynamic film barrier essentially "floats" the components in bearings, and allows them to glide in cylinders, etc.
The residual, THICK oil will provide considerable hydrodynamic lubrication WELL before oil pressure is "UP"
oil pressure is an artifact of the oil pump providing excess capacity to supply the bearing side leakage...provide more oil than the system needs, and oil pressure goes "up".
Bearings can and do draw their own oil at sub atmospheric pressures...provided the oil is there, which is what the pump provides.
But those are not in play upon immediate start up. But the TBC is always present, at all times.
The thick residual oil will provide closer to hydrodynamic for the brief few seconds that there's no oil pressure.
The "warmup wear occurs in the middle...when oil pressure is there, but viscosity is dropping...see the sequence IV wear tests...the oil is there...the pressure is there...and wear occurs.
It is actually developed and promoted by the oxidation of the oil.
Contact pressure/heat, not really oxidation.
Fresh OCIs will degrade that TBC until it is re-established via heat/oxidation again. This is why longer OCIs actually show LOWER wear rates in nearly every application I have ever studied.
You are quoting that used oil pin disk experiment again...it didn't actually suggest what you are stating.
Many of us have heard the old adage that "XX% of wear occurs at start up ..." Well - that is only somewhat true. It does occur, but it also will become almost non-existent as the OCI ages, due to the TBC.
No, the wear occurs during warm-up...the oft repeated addage on BITOG, and here is wrong.
Read my normalcy article. Purchase and read the SAE study I reference therein.
But the SAE study doesn't support your assertion.
Simply put, start up wear is not going to be greatly affected by the grade you choose.
I'll pay that
And for that matter, neither is the overall wear rate, despite all the fear mongering about thin lubes
Myriad of papers have wear and high shear viscometry linked, statistically...until advanced additives are brought into play, and wear with reduced viscosity is reduces, but not eliminated.
Real world proof, my studies of more than 10,000 used oil analysis, shows this grade topic is an overblown issue. A properly spec'd lube in a reasonable range is what is important. The rest is just hooey. And for anyone who disagrees, I ask for you to show your proof to the contrary of mine. Not interested in opinions, nor marketing hype or owner's manual "recommendations". I'm seeking real world wear data that would contradict mine. And to date, I've seen no one step forward to be able to do so.
Who's doing the "properly speccing ?
If it's to be "properly specced", and "owners manual hold no sway, then what is the determinant ?
Wear at start up is not retarded by the oil film; it is the TBC that averts wear in the first few seconds. And the grade you choose has no real effect in the development of that TBC layer. Only time and heat promote that beneficial oxidation layer developing. And once it's there, it does not drain off as does the oil.
OK, now that you've made the statement, then how does your extensive UOA determine which is start-up, and which is operational ?
Why is sequence IV, the period between the thick oil cold start, and warm engine/oil the "sweet spot" for wear, according to people who have actually done a sequence IV wear test
