Originally Posted By: lockguy
Originally Posted By: LeakySeals
Originally Posted By: steve20
with an engine that burns a quart every 3K I'd use SuperTech conventional and be done with it. A worn engine is, a worn engine -- no use putting syn in it
I could never do that. Paying a little extra for oil at Walmart is a whole lot cheaper than replacing the car or engine teardown. I buy sludge bombs cheap that don't run so good as commuter cars. Clean them up with additives, nurse them back to life on quality fluids and go another 200k. Thats who I bought this car from at 137k. Somebody that was pouring in the cheap stuff. Engine could not maintain idle. Paid $2k cash and towed it away. Just a fouled engine that burns a little oil. Sludge bomb.
Im pretty sure you don't get a prematurely worn engine from cheap oil, you get it from not changing the oil when you need to. I use the cheapest gf-5 oil i can find and my engine is fine.
Some engines are more prone to lubrication related issues than others. Also, should you have to extend your OCI for whatever reason, you'd be safe with some of the better lubricants vs the cheaper stuff. Modern cheaper oils aren't like days of old, but I'd be concerned the used oil analysis might say something different.
