The Hyundai Sonata six - speed automatic transmission in my signature comes with no dip stick and a 100K mile rating on the synthetic ATF ... *This is fine if you don't plan to hold onto the vehicle for more than the 100K Hyundai warranty - however if you plan on keeping the vehicle more than 100K miles then I believe you would want to do a drain & fill every 30K miles or so ? ... While the Hyundai transmission does not have a dip stick you can add fluid via a small opening in the engine compartment - then via a over flow bleed nut / bubble level can bring the ATF up to the proper level after a ATF is drained . I also believe if you do a "drain & fill" at regular intervals (no transmission filter on this Hyundai) you could get well over 200K miles on the original transmission ... If you never do a drain & fill on the ATF of this vehicle you may not be going much more than 100K miles before you develop transmission issues ... Your thoughts on "sealed" automatic transmissions ?
