Originally posted by grbr95:
I've been told by several mechanics that it is better to run 100% gasoline instead of the stuff blended with 10% ethanol. They claim that it burns cleaner and that the 10% ethanal blended fuel can harden and leave deposits. Is this true? If this is true, then why is the claim made that the E85 gasoline which is 85% ethanol burns really clean due to all the alcohol?
You need to find a mechanic that knows what they are talking about.
I've used 10% ethanol in everything that I own since the 1980s and never had an ethanol related problem. That includes several vehicles with well over 100K miles on them, small engines (both 2 and 4 stroke) and tractor engines. I've never had a problem with water accumulating in any tanks either. Nearly all newer vehicles have a closed fuel system. If you get water condensation in the tank you have non-ethanol related problems.
As far as mileage goes I consistantly get higher than the 30MPG highway rating with my 2005 Subaru using 10% ethanol. So either the Subaru handles 10% ethanol much better than other cars on the road or most of the fuel economy hit is related to driving habits.
Even with a fuel mileage decrease by approximately 2% a vehicle that averages 30 MPG on the highway would average 29.4 MPG using ethanol-blended fuel (30 * 2% = 0.6. 30 - .6 = 29.4.). Since 10% ethanol is less expensive than regular unleaded (usually by .10/gallon around here) it's more cost effective even if there is a slight fuel mileage decrease.
I have had one 1959 Power Wagon that I had to do carburetor work on-however that truck was from Washington and had not run on ethanol. It needed carb work when I purchased it and had it shipped here. After rebuilding the carb it ran fine on 10% ethanol for the 3 years I owned it. It's now owned by a collector in California and still runs like new. I don't know if he currently uses 10% ethanol or not.
I did need to clean the carburetors on a couple of old tractor restorations-however those tractors had always been sitting for several years. No matter what was blended with the fuel it would have varnished and clogged the passages.
Bottom line-ethanol is here to stay in one form or another. CRP acres are starting to be pulled out for corn production (there are around 32 million CRP acres). So there is an added benefit of not paying farmers to idle the land. Use ethanol and don't worry about it.
