1.5 Way LSD - What oil?
Australia
Hi everyone,
I have a Mitsubishi 5 speed manual from an FTO.
It has a 1.5 way LSD in it.
According to the gearbox manual:
"Hypoid gear oil SAE 75W-85W conforming to API classification GL-4 or higher"
Would the Motul LSD oil type 2 FF 75/90w which is GL5 be good to use?
It is specific for FWD cars that share the oil with the diff and transmission and run mechanical LSDs in them.
Originally Posted By: edwardh1
what are fto and lsd
FTO is a sports FWD car that Mitsubishi made. It uses the same gearbox as the late 90s/early 00s Mirage.
LSD is a limited slip diff, mine being an aftermarket 1.5 way clutch type.
