JHZR2
Staff member
Hi,
Since Im doing all the coolant replacement work on my 91 BMW 318i, I figured it good to get a new radiator cap. My new cap is stamped 200 - 200 kPa=2bar=30 psi... The old one is 140 - 140kPa=1.4bar=20 PSI.
I double checked and my car currently has the lower pressure cap, but the higher pressure cap is technically correct and spec.
Am I hurting myself running the 1.4 bar cap? Am I hampering cooling?
I do know for a fact that I get high NOX. If Im not overheating or venting steam, can I assume that the coolant inside is the right phase, and not an issue at the current 1.4bar? Will I get more/better cooling at 2bar?
My car does not let off good heat into the cabin - higher pressure could theoretically be hotter - but would this really help much?
What is the weakest link in the system to go if I upped the pressure??? Hose? heater core? radiator? head gasket? While I dont want premature failures, if the higher pressure cap buys me something good, and still is the 'weakest link', then all is well - my main concern is a ruptured heater core or headgasket.
Any insight would be appreciated.
Thanks,
JMH
Thanks,
JMH
