Vehicle: 2013 F150 with 5.0 V8. Recommended oil is 5w20.
First oil change after purchase (@12k) was with Amsoil XL 5w20.
At 22k (OLM
At almost 25k, changed back to 5w20 using Amsoil SS.
What I noticed was that under light acceleration, there was a slight reduction in responsiveness, that I can describe as what seemed like a delay in the valve train adjusting itself to additional gas pedal; it seemed the thicker oil had more resistance to the change required for the timing advance.
On longer trips(same as taken with 5w20), noticed a slightly lowered mpg. Not enough to be statistically reliable/significant, but enough to notice in both the mpg readout in the truck and hand calculations as well.
On short trips in town, noticed a large mpg difference, from about 15 with 5w20 down to 11.5 with the 0w30(both indicated by vehicle). Since the around town driving is consistent short trips that don't vary much, this is more reliable than the long distance and is not really affected by wind.
On startup with 0w30, noticed it cranked slightly slower as well as taking longer to crank.
Power at full throttle did not seem to be affected, although the engine was not as free revving, perhaps the result of the delayed valve timing change.
Part of the mpg could arguably be from winter blend of gasoline, which here in northern MT starts in mid to late September; however based on other threads/data on winter gas mpg changes, the magnitude of the in town mpg change can't be solely from the gas blend.
As stated in the title, test was nonscientific. The only data that is not subjective is the mpg. YMMV, but I wanted to share the experience with BITOG, since there has been so much discussion about this issue.
I made sure to try to objectively observe the changes in engine behavior during the test, and am pleased to report that the negative aspects noticed during the short run with 0w30 have gone away once it was switched back over. MPG remains to be seen as I just changed yesterday, but will keep an eye on it for the next few months.
At 22k (OLM
