Honda seems to do fine with it, yet VW has a reputation for early failures...and they historically use some of the thicker oils on the market.And the rash of early timing chain failures continues unabated.
My OCD is triggered!I drive a 2020 Honda Accord Hybrid that is spec for 0W20, but I am using a mixture of 2 quarts 0W16 and 2 quarts of 0W20. My next oil change will most likely be 3 quarts 0W16 and 1 quart 0W20. Someday, I plan to do all 4 quarts of 0W16, but my car is NOT spec for 0W16, but nothing will happen to my car using 0W16. Besides, it is not oil that I plan to use forever, but I want to know that I can mix 0W16 any time with 0W20.
I like to hypermile and when I hypermile, I get over 60mpg.
And this is my stash of oil for my next oil changes ahead of me.
And this is what I have been getting so far on this tank of gas since I changed my oil using 0W16 for my first time and starting off with a new full tank of gas. I am getting over 63mpg so far.
"Startup wear" isn't the main period of wear, warmup is, where materials are heating changing shape and size to get to where they are supposed to be at operating temperature. Since oil pumps are positive displacement, there's very little difference between the time it takes for a 0w-16 and a 0w-40 to get to the top most part of the engine.I mean, it is going to reduce startup wear which is where most of engine wear occurs.
I think you are messing up tolerances and clearances. While machining tolerances have steadily improved sine the 70's for the most part (the exception being bulk-fit pistons vs hand fit) clearances have remained the same. Engines are no "tighter" than they were back in the 1960's, so no, they don't need thinner oil. Improvements to rigidity, coatings, and surface finish have enabled the use of thinner oils, particularly when coupled with oil temperature control.Not to mention engines are made of much tighter tolorances today, so they need the thinner oil.
OEM's are also motivated by CAFE in North America, which has been a significant driver in the pursuit of thinner lubricants, which improve fuel economy, most significantly during the warm-up and around town where oil isn't up to temperature.Personally, I leave it up to people who are much smarter than I am. These companies spend millions of dollars developing and testing their engines and if they say to use a certain grade, Im good with it.
Yet you just said you personally leave it up to people that are smarter than you. What if that person's engine calls for 10w-30? Or an even heavier oil like 0w-40?Im much more a fan of people who think thinner is better than I do the people who still want to put 10w-30 in their engines, like its still 1985.
Yes, as I said earlier, I refuse to watch his videos.I personally wouldnt put much stock in anything that Scotty says. I saw one of his videos one time where he said that if you arent taking the wheels off of your car, you dont need to use jack stands becuase it wont crush you anyways. Sorry but if you are under either of the vehicles that are in my driveway and the jack fails, it will seriously injur or kill you. I find Scotty's videos entertaining sometimes but nothing more, some of his opinions are, "interesting" to say the least.
I’m waiting for 0w-0 oil to make my engine last 200x as long
honda has 0w8 already, so that's 100x longerI’m waiting for 0w-0 oil to make my engine last 200x as long
Wait till we get to 0w-10. Your engine will actually get younger as you drive down the road.
