09 LX570 Gear oil
burbguy82
$100 site donor 2024
NC, USA
Looking for a good sub for toyota 75w85 liquid gold gear oil for my LX 570, for the front rear and center diffs. I have heard that GL5 is no good for the center, and 75w90 is fine for the front and rear. Many use Redline 75w85.
Does HPL have a solution for this vehicle? Who is the guy from HPL on this forum?
What does your owners manual state as the fluid requirement for the center diff or transfer case?
I use Amsoil Severe Gear 75W-90 or -110 in my Tundra differentials that spec 75W-85, but absolutely would not hesitate to use HPL next time.
Based on the owners manual online at Lexus, the transfer case uses oil type “Gear oil API GL-5” with recommended viscosity of 75W-90.
I will also add that the flexible bags are much easier and faster to use than the standard quart bottle.
As with nearly everything, how deep is your pocketbook? I settled with Valvoline as it was the lowest price name brand 75w90.
I have used Valvoline for years, but just trying to get a consensus on what other have used in this type of vehicle. Toyotas are very new to me. I am not going to be paying 60 bucks a quart for Toyota 75w85. And if I have to give up that much, I would rather give it to HPL or Amsoil or Redline.
Valvoline is good stuff. Toyotas usually aren't picky with fluids, and differentials usually aren't picky, either :)
evidently in the later years, special toyota juice is needed for the center diff, but at least the 09, requires GL5 gear oil.
75w90 GL-5 is what is speced for the T-case. Check your Owners Manual.
I'm running 75w90 GL-5 in the front and rear diffs, and T-case of an SUV which was built on the same assembly line as your LX.
I use and am pleased with Redline in my vehicles. Have lots of experience with it in those, and in professional racing.
what year is your land cruiser?
For T-case: https://www.amsoil.com/p/amsoil-75w-90-manual-transmission-transaxle-gear-lube-mtg/?zo=515729
Or you could use the lighter MTF as I do in my Tacoma
For differentials: https://www.amsoil.com/p/amsoil-severe-gear-75w-90-100-synthetic-gear-lube-svg/?zo=515729
or you could used the 75W-110 rear and 75W-90 front as I do in my Tacoma
That's what I thought. IIRC circa '14 with the Gen 2.5 Tundra they started calling out the single weight? 75W? I think
I used the Amsoil MTF in a '15 Tundra and the owner claims it really does go into 4hi more readily (something I read online but didn't believe)
Even so, you hear plenty of anecdotal claims that a Toyota dealer will just pump 75W90 in there and call it good
