Hi,
Continuing solving some problems I have with the car (probably not well taken care of during its lease), I have a noise, increasing with the speed, not linked with the rpms, from the drive train.
A BMW dealer mechanic got a look at it (put it on a platform and check under there), and he believes the noise comes from the manual transmission case.
First thing to do will be to do a flush of the trans, and then I will see if the noise is gone or if I need to look further.
My question is that the mechanic told me that on the N52 engine, the manual transmission case has no drain plug, only a fill plug, as it is supposed to be a "lifetime" fluid in it.
So to change it or flush it, you need to suck it up before refilling. Is it true that there is no drain plug?
Is it easy to do a flush on a manual transmission for a N52 engine?
I will not do it myself anyway, but the BMW dealer mechanic is 115$/hour while a mechanic who will change the fluids in the Miata soon is probably at about 70$/hour... and will not try to sell other gizmos at the same time like the BMW technical advisor.
Does an indy shop can do the flush or do I need to go through a BMW dealer?
Thanks for your help and advise.
