07 impala suspension creak
kansas/KCMO
Ok experts here is the issue. There is a creak when taking off and coming to a stop along with when I turn the wheel while stopped. The turning wheel is not replicated when the vehicle is jacked off the ground/ no tension on the suspension. To note every part of this suspension was replaced about 10000 miles ago due to loose ball joints to include the strut assembly, control arm, wheel bearing, tie rods and axle. Any ideas on what to try next?
I mentioned this earlier, have a qualified person inspect the front end. It is ridiculous to troubleshoot on a forum when safety is at risk.
Some of the suspension places now have these little sensors that they can attach under the car to listen for the noise. I think they display a graph to show where the noise is the loudest.
Might also be available to rent if you want to do it yourself.
