Originally Posted By: Juhsga
Hey Critic,
Would you be able to tell me after I remove the pan to replace the strainer/filter what size the retaining bolts are and if I'll need deep sockets and/or extensions to remove them. I only have a really minimal set of metric sockets and one ratchet. What other tools do you recommend for this job before I begin?
~J
P.S. I came across this forum where it gives a little more info about "power flushing" with cooler line ...
Quote:
It is theoretically possible to do your own transmission flush of sorts by disconnecting a transmission oil cooler line, letting the car idle in gear and adding fluid through the dipstick tube as the old fluid is pumped out. But I'd be leery of trying this due to the dangers of running the transmission low on fluid or driving the car over my foot. It can happen!
Found
here!
Is this what is meant by "power flushing" or do I just drain most the fluid out from the cooler that way more of the fresh fluid is exchanged? I really appreciate everyone's help and expertise.
I have never dropped the pan before, so I can't answer that question, sorry. In the past, I drained the pan, refilled with new fluid, then proceeded to disconnecting the cooler line for the flush. The drain plug for the pan is either requires normal sockets or an allen key socket.
Power Flushing, Fluid exchange, flush, etc-- different terms for the same thing. You will always get the most complete fluid exchange by draining the pan and refilling with new fluid prior to disconnecting the cooler line and starting the engine. On most Toyotas, you will be able to "pump" 2-3 quarts out of the cooler line before you will need to stop the engine and add more fluid. Forget about adding fluid while the old fluid is pumping out-- it's likely that you'll make a big mess if you don't have someone keeping an eye on the hoses. Plus on some cars, the old fluid pumps out too quickly for you to refill simultaneously.
