I changed the transmission filter and ATF by dropping the pan(cleaning it up rigorously) on my CLK500 at 72k. Did the same thing by just opening the drain plug and drained nearly 4-4.5 quarts at ~78K. It has 722.6 AT and currently at 82k. No issues with shifting and zero problems with transmission, so far.
Question is, what is the possibility of this part(A203 540 0253) needing any replacement? It's an electrical connector for the transmission. I don't see any visible leaks or anything? Is it more like a preventative maintenance item?
Can anyone please share some advice or input? Thanks for the help.
