Just though I would share some photos and my experience servicing the Corolla transmission. I did the first drain/fill on this car around 28K miles. I've been doing regular drain/fills since then. It's had Schaeffer All-trans, Maxlife, and now Amsoil.
Yesterday I dropped the pan for the first time at 126,500 miles. Everything looked good, fluid was very bright red. The magnets had a lot of crud on them. There was hardly any grime on the pan itself and a mild amount on the filter.
I changed the filter as well. Used the Napa kit. I had high hopes for this since it came with a rubber gasket and not a cork one. Plus, the parts dealer(online) wanted a nice chunk of change for their filter and gasket. However, I wish I would've gotten the Toyota pan gasket now as the Napa gasket was about 1/2" too long. No way it would fit. I ended up re-using the factory gasket as was still solid and pliable. Filter worked just fine though. FYI, the dealership in town wouldn't even give me a price on a filter, he said "you don't replace them, just clean them, as they are just screens". Well it's definitely replaceable.
It usually takes 3-3.4 qts when doing a drain/fill. Dropping the pan and changing the filter yielded about right at 4qts. Amsoil and 4oz LG went in. So far so good, nice shifting and no leaks(knock on wood).
The material on the magnet looks so white because of the way the sun hit it.
