I have been working on my Honda all day, what a pain in the rear !! I have never had any problems out of any Honda's I have owned, however this one problem is really taking it's sweet time working itself out. My car (2002 Honda Accord EX 2.3L I4) while idling the other night ran hot, well not in the red hot, but started steaming out of the overflow, and temp gauge ran about 3/4 way up. No radiator fans working, so I check with meter for voltage, ohm etc general trouble shooting. I was reading all over the place, so I jumped straight from the battery, and still nothing, so I purchased the motor for the fan. The motor will not fit, so I check the motor to make sure no broken wire, something simple, and the motor spun right up on the bench. So I check the pigtail, so resistance however very little, so clean with contact cleaner, and nothing, it would not spin up through the pigtail... Ok no problem I remove the pigtail for tonight, and plan on replacing it with one of the automotive generic pigtails tomorrow. Then it done it again after straight wired to the battery, this fan motor is really driving me crazy !!
Now I need to find the part that fits my car, I can drive it like it is for awhile, as it's cool, I drive mostly interstate, and I don't need a/c now. I'm just stumped how both fan motors could go out, neither motor will spin up jumped straight from the battery now, and they would not to begin with, however after working on the radiator fan mainly it would spin up fine, then nothing. Any idea what could have caused the motors to go bad on both the radiator, and a/c fan ?
Any thoughts, help, and info on where except ebay I may be able to purchase a replacement motor for the radiator fan ? A bit of searching shows if the in stock fan motor does not fit from auto zone then it's hard to find the correct motor. I will check the other local parts stores tomorrow. Also any pointers on the best pigtails as I will need to replace these, and I want them all the same.
