Code:
ATF used RLI ATF RLI ATF RLI ATF RLI ATF RLI ATF RLI ATF
Sample Date 2010-Jan-17 2009-Jul-16 2009-Apr-20 2009-Jan-19 2008-Sep-22 2008-Aug-16
Miles on oil 7,128 7,533 7,226 6,279 3,480 2,652
Miles on car 135,062 120,051 112,518 105,292 96,254 92,774
Make-up oil None None None None None None
% Tested Fluid 99% 97% 95% 92% 78% 63%
Lab: Blackstone Blackstone Blackstone Blackstone Blackstone Blackstone
Wear Metals:
Iron: 18 21 20 12 10 12
Copper: 40 49 40 33 17 10
Tin: 1 0 0 0 0 0
Lead: 6 2 1 5 1 1
Chromium: 0 0 0 0 0 0
Nickel: 0 0 0 0 0 0
Aluminum: 29 26 24 20 16 18
Titanium: 0 0 0 0 0 0
Silver: 0 0 0 0 0 0
Additive Metals:
Calcium: 276 289 294 270 265 230
Magnesium: 1 2 1 1 4 4
Zinc: 6 15 11 9 11 12
Phosphorus: 254 290 273 270 328 362
Barium: 0 0 0 0 0 0
Molybdenum: 0 0 0 0 0 0
Antimony: NT NT NT NT NT NT
Contaminant Metals:
Silicon: 7 7 7 6 5 6
Sodium: 5 6 7 7 8 8
Boron: 82 86 84 87 113 130
Potassium: 1 1 1 0 0 0
Vanadium: NT NT NT NT NT NT
Manganese: 0 0 0 0 0 0
Physical & Other Tests:
Viscosity 40C: NT NT NT NT NT NT
Viscosity 100C: 5.46 5.38 5.36 5.63 6.24 6.15
TAN: 1.4 1.4 1.3 0.9 0.3 0.8
Flashpoint: 390 350 375 365 380 400
Oxidation: NT NT NT NT NT NT
Nitration: NT NT NT NT NT NT
Water: 0.0 0.0 0.0 0.0 0.0 0.0
Fuel: NT NT NT NT NT NT
TBN: NT NT NT NT NT NT
Insolubles: 0.2 0.2 0.4 0.0 0.0 0.0
Glycol: NT NT NT NT NT NT
VI: NT NT NT NT NT NT
Sulfate: NT NT NT NT NT NT
Drain & refill was also done at 127,934 miles with RLI ATF.
Shifts are pretty much the same.
No visible fluid leaks.
Magnet on drain is, of course, cleaned every time.
The fluid is (almost) all RLI ATF, but there is some fluid that has quite a few miles on it as a result of drain & refill.
This is pretty much the same report as last time but I'm not going to go to a longer OCI due to the massive shearing that Honda AT do in a short amount of time.
Wear Metals:
Tin: 1 0 0 0 0 0
Lead: 6 2 1 5 1 1
Nickel: 0 0 0 0 0 0
Silver: 0 0 0 0 0 0
Additive Metals:
Barium: 0 0 0 0 0 0
Contaminant Metals:
Sodium: 5 6 7 7 8 8
