Hey everyone thanks for all your comments, just to add some additional details.
This is the bottom of the report I forgot to include:
Background on the Jetta:
-I am the third owner of the car. It was purchased with 104k miles and now has 125k. (Owner 1 had it for 90k Owner 2 had it for 15K). The previous owners had all used fossil oils till I switched over to M1 0W-40 after purchasing it (though the engine practically drank 0W-40) This past summer I switched to High Mileage M1 10W-40 and noticed slightly less consumption. Only recently did I decide to go with the fossil Valvoline 5W-30 based on the assumption that since the life of the engine has seen fossil oil why not go back? and also that the syn oil was possibly making its way through the seals. The fossil oil has been in the motor for exactly 1k miles now.
Maintenance:
-Prior to the reintroduction of fossil oil I was using an over sized VW Passat filter or M1-310 series filter (both of which allowed me add about 1/3qt more oil).
-The valve cover gasket/cam chain tensioner gasket/all PCV hoses have been replaced. The turbo was inspected and had minimal shaft play. I don't get oil drips on the floor nor do I see any plumes of smoke through the exhaust pipe. Past OCI's have been 3-3.5K miles (with 1qt oil being added off every 1K.
Current Problems:
I am experience boost problems which maybe related to a sensor b/c every time I reset the ECU I get normal boost.
Here are additional details related to my oil analysis as per my conversation with Blackstone labs:
- The high sodium content is related to Valvoline's oil composition.
-Insolubles weren't too big a concern
-No traces of coolant were found, a high potassium and sodium content would indicate coolant but luckily that's not the case here.
-The high copper/lead content "could" possibly be related to the oil cooler lines (I will investigate this on my own). And even if I used a syn oil, the results may not change all that much.
So my question to everyone is what oil to use now?
I drive the Jetta very conservatively and rarely rev past 5k RPM's (it's a 5-speed).
I have 6 qts of M1 5W40 Turbo Diesel Oil and about 10 qts of M1 0W40 . I live in the Northeast so I am leaning towards the 0W-40.
And should I immediately remove the fossil oil or let it run for another 1k miles and resubmit a sample to Blackstone?
