I haven't posted here in a while but figured I would post up an oil analysis for my current vehicle. 2022 Ford Ranger with the 2.3 EcoBoost. Free dealer oil change with the stock semi-synthetic 5W30 Motorcraft oil (not synthetic as noted on the report), oil change before this was with the same from when I bought it.
59,177 miles on the truck, 5821 miles on the oil, oil meter was sitting at 49%. Replaced with 6 quarts of Valvoline full synthetic 5W30 and a K&N HP1002 filter. Never used one of the K&Ns before but it was on special/rebate with the oil, might stick with them for this application, the nut on the end was a help.
I'm going to change the Valvoline closer to 5K this go around with the same and do another analysis after the second Valvoline job. I'm not thrilled with how this one turned out but I'll see how the Valvoline does after a couple 5K intervals and go from there. Most of the miles on this are back and forth to work, about 20 miles 75% interstate and 25% back roads, I did make sure to change it right after getting home from work so not after a short trip.
Here's a PQIA VOA of the oil that came out: https://pqia.org/ford-motorcraft-sae-5w-30-api-sp-synthetic-blend-motor-oil/
