hi guys, first of all ill introduce a bit myself. i've been reading here for a while now but never registered. this time i had to since i have a few questions i'd like to debate here hahah.
the main concern i have with oil is because i take my car to the track, and the engine is somewhat "special". it's a toyota mr2 spyder, with a 2zz-ge engine swap. for those who dont know the engine is a 1.8 with 192hp stock, being an na engine this means high rpm. it's got vvtli, which is toyota's vtec, both camshafts have two types of lobes, one for idle to 6000rpm, and the big one which takes the valvetrain up to 8250rpm. it's got a pretty narrow powerband (2250rpm) so you have to keep it there if you want to move.
current spec on my oil system is as follows:
-bigger and baffled sump to reduce oil starvation
-16 row oil cooler mounted on the side scoop
-aprox 1.3/1.5 of added oil capacity (around 6L total)
what i've been using and doing:
-meguin super leichtlauf 0w40, its supposedly the same as liqui moly synthoil but cheaper. the msds says its got around 40 to 60% of PAO. meets a40 porsche spec.
-no longer than 3500/4500km OCI, with 2 trackdays maximum. my trackdays vary from 1.5h track time to 8h. we could say that i usually try to do as many laps as possible on an open pitlane mode, which on a 4h track day would equal 50 total laps, with 18 hotlaps of around 1:53 min each aprox and the other 32 laps would be aborted or cooling laps. bear in mind hot laps are 100% pushing, video for reference for whoever is interested:
knowing this data, what would you recommend?
toyota specs 5w30 oil for this engine, while lotus says 5w40.
the car doesn't see a lot of street usage, most kilometers are covered on the highway journey to the race tracks (i don't tow it).
i don't know if i should switch to a thicker 5w40, do longer oci's, or even shorter with cheaper oil... engine seems fine after a total of 10 trackdays and 20.000km (2 years).
money is a concern since im trying to reduce costs on my track car since everything is getting so expensive nowadays and my pockets aren't big xD, so boutique oils like redline are out of the question, they are also more expensive in spain than in the states.
i'd like to know if doing a longer oci (3 track days instead of 2) with current oil would be a good idea, or if a cheaper oil meeting a40 would cut it for current oci. i've thinking on oils like:
-total quartz 9000 energy 5w40: meets a40 and 5 liters cost 25€, way cheaper than the meguin im currently using (9.5€ per litre).
-shell helix ultra 5w40: meets a40 and 5 liters cost 22€.
-mobil fs 0w40: classic, factory refill for porsche, not too expensive...
im open to suggestions but bear in mind oil market in europe is different to the one in the states!
thanks!
thanks!
