Yet another vehicle that makes me wonder "why do I pick up the phone"
Coworkers kid was given this '07 Sentra 2.0S (83k miles)
2.0 MR20DE with a RE0F10A Xtronic CVT
I was deputized with getting it through NJ Smog inspection, plus general fixing and making it roadworthy
It was laid up in a driveway in PA for a few years, so someone threw a battery in it, topped off the oil and said good luck kid
It comes to me loud, smelly, and with many dash emojis
There may have been a rodent problem, the blower motor sounds like a 747, and the factory cabin filter was clogged solid
And underhood insulation was chewed
It's gonna need a blower motor and thorough HVAC cleaning
When it first came to me, it was running lean and stalling
It had lean codes, engine speed codes, and CVT low pressure codes
That'll do it...
Nest in the air filter housing?
You bet
So I dismantled the air intake system, and washed it all out
Cleaned the throttle body/MAF, and replaced the torn intake tube
Cleaning the throttle body, replacing the intake boot, and doing an Idle air volume relearn really smoothed out the engine
I'm still putting a Denso crank sensor in it, this era Nissan was awful about cam/crank sensors
It badly needs a PCV valve, you can significantly speed up oil filling by popping the dipstick out
OCI, and drain + fill the CVT
What does this figure mean?
Tried to straighten out the grille, every marker/parking light bulb was out, so I replaced every exterior lightbulb
Kid never noticed marker lights, or that the turn signals were dual filament
Swapped out the trunk struts, it no longer tries to unalive you when a gust of wind comes by
It came with 1 key, and no key fobs
It left with 1 key and two working keyfobs
Two new keys are on the way, I hope my Autel can do NATS
This 2.0S is oddly optioned
No ABS, but power trunk release and aux jack?
Rear drums and wheel covers
No cruise control, but intermittent wipers?
The battery terminals were badly corroded, and the hold down was MIA
She ain't pretty, but she'll do the job
I got all but one readiness monitor to set, hopefully he can get it smogged and we'll proceed with other work
