Patio base suggestions
Greenville, SC via Chicago, IL
My wife wants a patio from our walkout basement. It would be roughly 20x30, run under an existing porch that's 11'ft of the ground. I also have a septic tank that would be covered by whatever base I choose to use. The lid of the tank is about 1/2''in below grade. I feel that I have a few viable options, decomposed granite, pea gravel, or pavers. I suppose I'd use treated timber to outline the space and fill with rock or pavers, and put down a barrier below the rock or pavers to keep grass and weeds out.
Thoughts on any of these products? Personal experience?
From the slope I see, I would be worried about the gradual movement of loose fill to the bottom of the borf=dered res. I think you shouls level it, out a small retraining wall ate the vase and go form there.
What ever I chose, I'd make sure access to the septic tank lid does not get hindered in any way. It must have a riser on it already if it's that close to the surface?
