OG Fram Titanium FS3593a C&P
BrendanC
$100 site donor 2024
Houston, TX
2003 honda accord 2.4l K24. 175k miles
FCI was 2500 miles, OCI was 5000 miles
out/off: 4 quarts Valvoline R&P 5w-30 with 1 quart HPL EC30 with fram titanium FS3593a
in/on: 5 quarts HPL PCEO 5w-40 with OG Fram Titanium FA3593a
planning this OCI to 12k with a UOA at the end to see if it can go further.
filter looks great. the first filter was an endurance FE7317 but my filter cutter won’t cut that small so i didn’t cut it open. car was a rental car until 100k so no telling what oil was ran in it prior to my woman buying it. i started servicing it at 150k with PUP and OG Titanium’s. it’s had 2 BG EPR flushes at the end of the last two OCI’s with a berrymans hot piston soak and a new PCV valve on the last OCI. car used to burn a quart/1000miles and now it’s come down to less than a quart per 5k. hoping the HPL PCEO will clean the rings the rest of the way.
Can’t make out date code due to glare. Nice filter pictures. Thank Yiu
Looks very good.
I got a long term Fram Ultra 7317 with 66K miles so far with multiple drain & refills.
Hoping to get 80K miles before cutting it open.
I'd be curious on how the Ultra holds up with that kind of mileage. How long in time (months) has it been in service?
Can you make out date code? What’s OG ULTRA mean? Dumb question I know
"OG" (Original Gang or Original Gangster) means in this case the original design with the wire-backed media. People have been referring to that Ultra as the "OG" here for quite awhile.
OG means "Original Generation" not "Original Gangster" :ROFLMAO:
Google it ... just because you think what OG means doesn't mean what it really means from its inception. 😄 Do some research. You won't find that OG means "Original Generation" ... that's only what you think it means.
I could make up all kinds of acronyms such as:
OD = Original Design
OC = Original Configuration
OWB = Original Wire Backed
OU = Original Ultra
etc ...
