If you wish to have the somewhat higher HT/HS that a 30-grade brings, why not do it year round? Unless you are starting at somewhere around -35, there is no practical difference between an oil with a 0W winter rating and one with a 5W.
It's not about flow to the turbocharger. If the oil pumps it will flow, and that is represented by the winter rating. What you want for a turbocharger is sufficient MOFT and oxidation and deposit resistance. "Closer the 2 numbers" is pretty irrelevant here, pick an oil with other attributes which contribute to turbocharger longevity and then pick one with a winter rating that is appropriate for your starting temperatures. 0W for -35, 5W above that up to about 0, and 10W above 0.
