I've been on BITOG for a while now and I've read several posts in the past about people getting inconsistent readings when checking the oil level. I've also seen plenty of posts asking about what kind of oil to use.
The best kind of oil to use is the kind that meets/exceeds the manufacturer's recommendations. The oil specifications can always be found in the owner's manual. For my Chrysler, I look for these 3 things when choosing oil: API certification, a viscosity of 5W-30, DaimlerChrysler Material Standard MS-6395.
Oil life monitors display oil life, not the quantity of oil. Therefore, it is a good idea to check the oil level once a week, or during each stop for fuel.
Always refer to your owner's manual. These are general instructions for checking engine oil.
1. Get engine up to normal operating temperature. If your vehicle does NOT have a coolant temperature gauge, run the engine until the cooling fan turns on. Make sure the vehicle is level.
2. Turn off the engine and remove the oil dipstick. Wait 5 minutes before reinserting the dipstick to check the oil level.
Checking the oil when the engine is cold can give you an inaccurate reading. Checking the oil within 5 minutes of the engine being shut off can also give you an incorrect reading.
