They are not metallic. Another forum member thinks might be clutch stuff from description and pictures. I think they might have been more on the rock catcher internal screen and not sent through. They came out as I was doing the drain and fill. That turned into replace with a new magnefine due to what I saw. I still need to cut the filter media apart. The external filter on the Pilot is after the added factory cooler. I'm wondering if some might be blocking my external cooler ports. I'm contemplating reversing the flow to cooler and run 4 qts into a jug to backflush it to check it.
Tranny has been up to 230F for about 15 minutes when going slow up a bunch of hills with 2000lbs trailer (840 trailer, 1200 load) weighed on scale. That was the max I have ever seen it but just started monitoring with VeePeak and OBD Fusion recently. That trip it was at 210-215F for about 1 hour sitting in almost dead stop traffic on I-95, idling along less than 10 mph and almost 90F ambient. Trailer is small utility used to move the kids back and forth to college 100 miles away not going over 65mph, normally much less (Long Island traffic to Bridgeport CT.)
My son took it multiple times for road trips with friends without trailer and temps didn't go over 200F.
Too bad Dave doesn't make HPL Red so it looks more like stock. Otherwise I'd be tempted to try the HPL Green but that will be really obvious something different is in there. Then all the debates and choices between VML, Idemitsu, Aisin, Amsoil Bluecap, D6. VML being easiest since WM carries it for not much money.
