How would you or anyone know if it was doing "fine" or not?
By a UOA
I’m running here HPL NO VII 5w20 so far with zero issues; cold weather doesn’t bother duratech 2.0 engines.
I had put the No VII 5w20 Euro in the 2020 Transit Connect with the 2.0 Duratec we had. Was about 6k into the OCI when we sold it, so no objective data other than it didn’t use any oil at all during that time, and there was no mileage impact… although I attribute the latter more to my wife’s driving habits rather than the expected decrease caused by higher HTHS.Looking at the HPL spec sheets, the xx-20 oils with the highest HTHS viscosity (the viscosity that actually matters) is the 10W-20 PCMO (2.861 cP HTHS) and the no-VII Euro 5W-20 (3.267 cP HTHS). That no-VII Euro 5W-20 has a KV (8.70 cSt) in the SAE 20 grade range, but a HTHS viscosity of a typical stout xx-30 grade.
What do you want to know? It starts off with their typically stout oil package, and then lumps in additional antioxidants to deal with the high temperatures and harsh environment. I’ve got it in my Ariens ZT and it’s been fine so far, 10w40 here but they’ve done a couple other grades IIRC.I’m about to buy a Honda lawn mower What oil should I Order for my first oil change
Thanks
Mainly is Honda oil worth ordering or is there a good off the shelf oil for an air cooled engineWhat do you want to know? It starts off with their typically stout oil package, and then lumps in additional antioxidants to deal with the high temperatures and harsh environment. I’ve got it in my Ariens ZT and it’s been fine so far, 10w40 here but they’ve done a couple other grades IIRC.
Can’t say anything bad about Honda oil because I haven’t researched it. But I have used both Amsoil and HPL small-engine-specific oils and have nothing but praise for both of them. Either one is definitely top-shelf protection for hardworking air cooled engines.Mainly is Honda oil worth ordering or is there a good off the shelf oil for an air cooled engine
I agree - with a slightly different spin. The Dexos 1 G2/3 of Red Line is junk.He should at least move up to the HMX or HPS line as the Dexos line is junk and overpriced.
The inexpensive PCMO is not GF6a / SP / D1 G3.From what I understand, the main benefit of the "no vii" lineup is that it won't shear down. Shearing is only really a problem with trucks that work hard (tow) or if you track your car a lot, you can probably get away with using their cheapest PCMO, it's significantly cheaper and has the same cleaning ability etc.
Wouldn’t call it junk but it’s just rebottled Phillips 66/Motorcraft with the Redline Label on the bottleI agree - with a slightly different spin. The Dexos 1 G2/3 of Red Line is junk.
Maybe you missed the member quote above my 11:37AM post. That's the only reason I used the word 'junk'.Wouldn’t call it junk but it’s just rebottled Phillips 66/Motorcraft with the Redline Label on the bottle
How cold does it get there ?Stupid question. I see the supposed advantages. Any disadvantages running this in a dexos application in the Midwest?
In the garage most of the time. Coldest start would be maybe 10 degrees if parked outside. Lots of long trips at 75 plus mph.How cold does it get there ?
