2004 GMC Sierra 4.3l V6 4x4 K1500 truck (new to me last year so first UOA to check all is okay) 5sp
2000 miles over many months with super short trips mostly during the winter. Sits outside only and saw below zero here and there. No make up oil, Chevron 5w-30 oil with a ACPF52 filter.
Code:
ALUMINUM 1
CHROMIUM 1
IRON 8
COPPER 2
LEAD 0
TIN 2
MOLYBDENUM 376
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 49
SILICON 6
SODIUM 2
CALCIUM 1515
MAGNESIUM 4
PHOSPHORUS 606
ZINC 727
BARIUM 0
SUS Viscosity @ 210°F 55.9
cSt Viscosity @ 100°C 9.05
Flashpoint in °F 400
Fuel %
Antifreeze % 0
Water % 0
Insolubles % 0.2
Blackstone's comments:
No problems showed up in the initial sample from your GM 4.3L engine. All wear read well below averages for this type of engine, which is a very good indication of normal wearing parts. Universal averages show normal wear after 4,200 miles on the oil. You easily beat those numbers after 2,000 miles on the oil, so you could run longer oil changes if you wanted. The viscosity read a little low, but that's not hurting anything. At 121,000 total miles, this engine appears to be doing extremely well. The low viscosity isn’t an issue. Nice first report.
I forgot to tell them what oil I used so they thought I used 10w30 Pennzoil like the Subaru I sent in the same time. Also messed up on the miles but I'll get that fixed.
My plan is 6 month OCIs with 5w-30 and filter change each time.
No TBN done.
Bill
Code:
ALUMINUM 1
CHROMIUM 1
IRON 8
COPPER 2
LEAD 0
TIN 2
MOLYBDENUM 376
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 49
SILICON 6
SODIUM 2
CALCIUM 1515
MAGNESIUM 4
PHOSPHORUS 606
ZINC 727
BARIUM 0
Fuel %
Antifreeze % 0
Water % 0
Insolubles % 0.2
No TBN done.
Bill
