From what I see... not a big issue. Local Ford dealer has two that are just sitting and sitting on the lot, unsold.
Yeah, I dont think big EV trucks and SUVs will be in high demand. Im almost certain those drivers will place convenience of the ICE over all else.From what I see... not a big issue. Local Ford dealer has two that are just sitting and sitting on the lot, unsold.
EV trucks are probably one of the worst choices for people who actually use their truck to do truck stuff like hauling and towing. The range loss is just too much, its 50-70% loss when loaded. Even worse if its cold out. If all you do is drive it around with a couple people in it and nothing else and can afford the price, its probably not much different than an EV car. If you don't drain the battery down you don't need to worry so much about the long charge times.EVs have their place. Trucks may not be the best choice for an EV.
This is more disappointing news, at least to me. I hope Ford gets it right.
It's on the news as well. Sketchy but mentions issues with the battery that halted production. They don't halt production for no reason, maybe it's an easy fix, maybe not. The news just broke.And just where does it say it is a battery issue? Another crappy article.
Headline says battery issue. Article speculates that it could be a battery issue.And just where does it say it is a battery issue? Another crappy article.
TFL came to a similar conclusion when they tested the Lightning. However, they didn't seem quite so negative and suggested that a larger capacity battery would solve most, if not all, the issues of range.EV trucks are probably one of the worst choices for people who actually use their truck to do truck stuff like hauling and towing. The range loss is just too much, its 50-70% loss when loaded. Even worse if its cold out. If all you do is drive it around with a couple people in it and nothing else and can afford the price, its probably not much different than an EV car. If you don't drain the battery down you don't need to worry so much about the long charge times.
Potential is the key word. Does not say because. Potential could mean anything.Ford spokeswoman Emma Bergg declined to disclose details of the possible battery issue, which is being investigated after a vehicle displayed a potential problem as part of the automaker’s pre-delivery quality inspections.
I'm gonna guess one caught, or nearly caught fire.... But that's just a guess.
I agree, the battery pack is too small. 200KWh is about the minimum for a full sized pickup truck.
If course not everyone but I suspect more than most think only because I certainly feel that way.
