Exactly. Dedicated hose. Every E0 pump near me has one.I only get E0 from the pump with a dedicated hose for E0. Also, I never had any issues using E10 in any of my OPE before E0 was available.
Saw this a while back, and hadn't thought about it before, but I only by E0 from the one place with a separate pump now.
I should probably still test it. Wouldn't surprise me if there was still some in it.
I should - you don't need a kit unless you want to know the actual percentage. If you just want to know if it has ethanol all you need is a sealed container and some water and the gasI bought an ethanol kit off of Amazon and tested my E0 a while back. No ethanol to speak of. The pump did have a separate handle for E0.
Just my $0.02
The E0 gas station (a Shell station in Madison, AL) I use almost all the time has a separate hose for the E0 gas and it is 87 octane. I don't think this station has higher octane E0 gas than 87. They also have diesel on separate hoses as well at a different pump island. The E0 gas from this station has always thus far worked great in my outdoor power equipment, even after a year or so in my gas can. I do always add PRI-G fuel stabilizer to the E0 gas after bringing it home. Nonetheless, after watching the OP video I am going to test it to make sure it truly is E0.Of the 3 stations that I use near me that sell E0, only one of them has a dedicated hose:
Station 1: 87E0 and 87E10 on one hose, 91E0 on a separate hose
Station 2: 87E10, 91E0 on the same hose
Station 3: 87E0, 87E10, and 91E0 all on the same hose
The variety is interesting. I've also learned that I'm one of the few that has easy access to ethanol free 87 grade.
+1 on the Pri-G. That stuff is all I now use. I put it in all the gas for my small engines............. I do always add PRI-G fuel stabilizer to the E0 gas after bringing it home.
I also use stabilizer in my E0 fuel purchases for the OPE. Both vehicles take premium so I end up just pumping 91 into my OPE tanks at the same time that I am gassing up the cars, but obviously I'd other wise have no issues running the 87 E0 variety.The E0 gas station (a Shell station in Madison, AL) I use almost all the time has a separate hose for the E0 gas and it is 87 octane. I don't think this station has higher octane E0 gas than 87. They also have diesel on separate hoses as well at a different pump island. The E0 gas from this station has always thus far worked great in my outdoor power equipment, even after a year or so in my gas can. I do always add PRI-G fuel stabilizer to the E0 gas after bringing it home. Nonetheless, after watching the OP video I am going to test it to make sure it truly is E0.
Central NY, Stewart’s gas stations. One hose, 87 and 89 E10, and 91 E0.I’ve never seen an E0 option with the other traditional grades. Of course you would be getting some ethanol from the previous user.
This is a good video that shows when you gas up your small gas can with "Ethanol Free" fuel, you might be getting as much as a third of a gallon or more of the Ethanol based fuel that was in the hose from the last customer.
This happens when several different fuel grades are shared with the same pump nozzle.
I never really thought about this. I'm lucky because the station I get my Ethanol Free 91 Octane from, is on a special single pump off to the side. There is even a class action lawsuit being filed by someone in California over this.
Everywhere I have ever purchased E0 had a dedicated hose. I tanked up the C-Max twice last week in PA and WV with 90 Octane E0. It was about $1 more per gallon than 87 Octane E10. Normally I purchase 89 Octane E0 at a $0.50 premium over 87 Octane E10. It occurs to me that I've paid a similar or lower premium to get 91 Octane E0 at Stewart's Shops in NY and VT.
Are any of you out there old enough to remember when Sunoco stations had a dial your octane pump? IIRC there were eight grades running up to 96 Octane. Those were the days...
Perhaps I should reviev my photos, but I thoguht that they did.Your Stewart’s in NY have dedicated hoses? Ours don’t. All around Rome and albany.
Distilled , BRITA filtered or tap ?You can add water to it and then skim off the good stuff.
