I bought a used scan tool, a fancy one that does a lot of stuff like give you live data and other good stuff
This is the first time I needed to scan the CEL after buying it.
The P0171 came up twice: one is stored, the other is permanent
Here is the data:
P0171 (1/2) Stored
Fuel Sys 1 -- CL
Fuel Sys 2 -- N/A
Calc Load -- 9.0%
ECT -- 144 F
STFT B1 -- 34.4%
LTFT B1 -- 3.1%
MAP -- 9 in Hg
Eng RPM -- 679
Veh Speed - 0 mph
Spark Adv - 19.0 deg
IAT -- 21 F
MAF -- 0.22 lb/min
TPS -- 12.2%
O2SLoc -- O2S11, O2S12
O2S B1S2 -- 0.130V
STFT B1S2 -- 0.0%
OBDSup -- OBD and OBD II
Run Time -- 380 sec
Command EGR -- 0.0%
EGR Error -- 0.0%
Fuel Level -- 99.6%
BARO -- 30 in Hg
ECU Volts -- 14.404 V
LOAD Value -- 10.2%
EQ Ratio -- 0.991
Rel TPS -- 0.8%
Ambient -- 16 F
TPS B -- 29.4%
ACC Pedal D -- 13.7%
ACC Pedal E -- 14.1%
Command TAC -- 0.0%
N/D_STAT -- NEUT
GEAR_RCMD -- Neutral
P0171 (2/2) Permanent
This car seems to only have one upstream oxygen sensor (usually there is one for each bank)
Here is the data:
P0171 (1/2) Stored
Fuel Sys 1 -- CL
Fuel Sys 2 -- N/A
Calc Load -- 9.0%
ECT -- 144 F
STFT B1 -- 34.4%
LTFT B1 -- 3.1%
MAP -- 9 in Hg
Eng RPM -- 679
Veh Speed - 0 mph
IAT -- 21 F
MAF -- 0.22 lb/min
TPS -- 12.2%
O2S B1S2 -- 0.130V
STFT B1S2 -- 0.0%
Run Time -- 380 sec
Command EGR -- 0.0%
EGR Error -- 0.0%
Fuel Level -- 99.6%
BARO -- 30 in Hg
LOAD Value -- 10.2%
EQ Ratio -- 0.991
Rel TPS -- 0.8%
Ambient -- 16 F
TPS B -- 29.4%
Command TAC -- 0.0%
N/D_STAT -- NEUT
