I just purchased my son a 12 VW Passat 2.5L, 5 speed manual. I promptly changed the oil to Belgium Castrol 0w40. Couldn't find any Green GC from my old VW days....I'm a Tesla guy now and haven't been on here for a while....
Anyway, I am looking to change the MT fluid. We live in Ohio, so we get some cold winters. What recommendations do you have? I am leaning toward Redline MT-LV....what's better?
The Redline MT-LV and others would definitely have better anti-wear components than any ATF.
NOTE: This list is only a “summary” list of MTFs available in the MTF Lubricant Market. It is not an endorsement nor a critique of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear.
A. These MTL fluids are closest to a Kinematic Viscosity of 6.X cSt@100C (About the same viscosity as Dexron VI ATF) and SAE 70 or so:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M655-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
7. Redline MT-LV SAE Viscosity Grade 70W/75W Vis
6.5cst@100°C
B. The next higher viscosity MTF would be the 7.0 to 7.6 cSt@100C versions(SAE 70W75) (About the same viscosity as the original DexronIII/Merc)
1.Royal Purple's Synchromax
2. Ravenol MTF-2
3. Honda MTF
4. VW part number G052512A2
5. GM Manual Transmission and Transfer Case Fluid
6. BMW (Pentosin MTF 2) MTF-LT-1, 2 ,3
7. Tutelo (Petronus, Italy, Product Code 1402)
8. Penrite Pro Gear 70W75 (Australia)
9. FUCHS Titan Sintofluid FE 75W Manual Transmission Oil. GL-4 75W Gear Oil
10. Redline Power Steering Fluid R
11. RAVENOL STF
NOTE: This list is only a “summary” list of MTFs available in the MTF Lubricant Market. It is not an endorsement nor a critique of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear. A.These MTL fluids are...
bobistheoilguy.com
