Motor Oil University Final Exam
Read Time: 7 minute(s)
101 | Operating temperatures and viscosity
102 | Oil grades
103 | Viscosity modifiers and engine oil
104 | Conventional vs. Synthetic Oils
105 | It’s more complicated than you thought
106 | What brand should I use?
107 | The terminology from SAE and API.
108 | Odds and Ends
109 | Let’s start over
201 | The Graduate
202 | Mid-Term Exam
203 | Glossary
204 | Final Exam
question 1
The correct answer is A- 0W-20
question 2
The correct answer is D- 100 cS
question 3
The correct answer is A- 1
question 4
The correct answer is A- 240 PSI, flow = 8
question 5
The correct answer is A- True
question 6
The correct answer is B- False
question 7
The correct answer is B- False. It can best be determined by driving the car with one type of oil and follow the pressures and temperatures of your oil.
question 8
question 9
The correct answer is B- False. The problem is thickening when the engine is turned off. With long term use the problem is also thickening. Engine oils grades are matched at operating temperature. It is after the engine cools that viscosities are an issue.
question 10
The correct answer is A- True. Although it may actually be preferential to use a modern 0W-30 grade oil.
question 11
question 12
The correct answer is E- No oil was recommended. They all are too thick at startup for daily use.
question 13
The correct answer is E- Shell mineral based 10W-40. You can mix any SM rated oil in there but this is my first choice based on my research.
question 14
The correct answer is E- All of the above
question 15
The correct answer is C- American Society for Testing and Materials
question 16
question 17
question 18
question 19
question 20
Congratulations on Completion!
