Raw egg will stop a radiator leak
NJ now SC
At least temporarily.
Watched the guys on Mythbusters punch a hole in the radiator.
Then they added a raw egg through the fill area and in 5-7 seconds the leak stopped.
A former brother-in-law had a sure-fire cooling system leak fix, too - half a box of instant mashed potato flakes. Try to guess what happened after the leak stopped. (Hint, arteries aren't the only thing that respond poorly to high starch intake...)
quote:
Originally posted by jmacmaster:
I think you're only supposed to use the white of the egg. Right? Or wrong?
The Mytrhbuster guys dumped the whole egg in the radiator.
I think you should use the egg AND the oatmeal. And a couple strips of bacon, maybe a cup of coffee... apparently breakfast food is good for radiators.
Hey,stopping in at a 7-11 or a supermarket for an egg while on the road for an easy quick temporary fix is good to know.
It just may get you home or to a repair shop.
I used some Barr's awhile back, and It seems that I may have finally gotten most of it out of the system. When I finally changed the radiator and other components I noticed that it was all over the thermostat, the radiator cap, and had plugged the overflow line.
