Anyone ever replaced the transmission filter for these automatic transmissions before? This is a picture of it:
I have no problem removing the pan, as this one has a drain plug as well to make drains easier, but does this filter just pop off or is it a bolt on? With all of those hole locations, it would appear to me that there is a set of bolts needed to hold it in place.
There is no mention of replacing this filter in the maintenance section of the owner's manual. It only mentioned to drain/replace the transmission fluid.
