Observation: M1 0W-40 In 5W-30 Application
1999 Chevy Express van, low miles, perfectly maintained, 5.7L. OM recommends 10W-30 for 0F and up, 5W-30 for all temps, severe cold, synthetic 5W-30 or 0W-30.
1. Oil pressure is instantaneous even with the few just above freezing morning temperatures I've had here. I expected higher pressure readings both cold and hot but the gauge reads the same.
2. Fuel economy went UP from 13.5 MPG to 16.6 MPG. My station could have switched from winter blend to summer but have not confirmed nor do I think the attendant would even know.
3. No loss of power, strange noises or other maladies I read here on BITOG that might happen.
Why? Because I had a gift card and it didn't cost me anything so I figure I would drain it if there was problems. Also, for pretty much every application that calls for a 5W-30 in NA, the M1 site recommends 0w-40 (which is named "Protection Formula") in Europe, including my van. I will leave it in for my typical interval. That means I will drain it in late October.
Mobil 1 0w40 has more manufacturer approvals and is reputed to be one of Mobil's best oils. I would have no problem using it in your application and I would probably go a little further on the OCI.
Why would there be? 0w40 is spec for most GM in some other countries. 0w40 is a lot thinner cold than some of the old dino 10w30 that was spec for the SBC years ago.
I remember in the early 70's some 10w30 was even hard to pour out of the can in winter, some didn't flow and blew a lot of engines if they were unfortunate enough to get it running.
The viscosity specs for my Hyundai are 5w30 or 10w30. M1 actually recommends AFE 0w30, which is currently being used as of yesterday. I'll get back to you with any observations.
Sorry, but that is just not happening as a result of switching from 5w-30 to 0w-40.
I don't question that your fuel economy went up. It just had nothing to do with the oil.
Why not ? Maybe the 40 weight is lubricating better thus reducing friction. In the UOA section, those Chevy truck V8's always have high wear numbers with 5W-30. On 40 weights, the numbers are always way lower.
What is it about the 40-grade oil that is causing it to lubricate better? 40-grade oil has a higher film strength to offer more protection in extreme operating conditions, but that comes at a cost of INCREASED friction - engine is spending more effort on pushing heavier oil around. Granted, these are very miniscule changes, but they are typically changes towards worse fuel economy, not better. Unless the OP was using 20w-50 previously...
Notice, he described a 23% improvement in fuel economy.
Someone should alert GM ASAP - they could be beating their CAFE numbers just by doing away with dexos and recommending 40-grade oils instead.
Agreed. If I was to make a point that point would be don't expect drastic fuel economy losses by upping a grade. The only meaningful change made besides the oil is that I'm idling less in the warmer temperatures. Other than that, no changes, which is why I mentioned the fuel blending. I always see MPG improvements when the stations stop selling the oxygenated winter fuel.
That right there explains your change in MPG.
I also noted that when I changed from Mobil1 5w30 to their High mileage blend that was 10W40 my fuel economy increased tremendously. It went from 24 mpg to 28. This was consistent and stayed that way until I sold the car. It was a 98 mercury sable with the duratec engine. I sold it with 240,000 miles on it and it still ran good but the body was deteriorating and showing wear.
With the brutally cold winter we had, I was idling as long as 30 minutes before driving off. Now it's get in, strap in, and go. Recently, I've had overnight lows in the 20's but it's been just above freezing when I leave. I was expecting higher pressures, sluggishness, and a drop in MPG. I'm not seeing any of that with the 0W-40.
I put M1 0w40 in my 03 Foreter and it's the best oil I've used yet in terms of keeping the engine quiet. It runs great on this grade.
Big time, and the rise in temps.
Because the laws of thermodynamics aren't suspended in Bitog-land...
Sorry, but thicker oil is almost always going to result in a small (read "difficult or impossible to measure") decrease in FE. I'm not saying the OP didn't observe a 20% increase in fuel economy, just that oil grade had nothing to do with it.
Where did you read that going up one grade would cause all of the maladies? Because I've never actually read that on this site.
Compared to a 10W-30 on start-up M1 0W-40 can be even lighter at temp's as high as room temperature. But make no mistake, compared to a 5W-30 like M1 it will be heavier at all temp's.
And unless your engine is worn, your OP gauge will tell you that, you will have better overall lubrication running the 5W-30.
For the same reasons, M1 5W-30 is a better lubricate choice in the 638 HP Corvette ZR-1 than M1 0W-40.
Can you elaborate on this? I can't see how this would be the case. Perhaps he'd had 0.001% better fuel economy, but I don't think that a 5w-30 is going to provide "better" lubrication than a 0w-40, particularly not M1 0w-40, which has more manufacturer certs and approvals than any other oil they make.
For daily driver duty perhaps one could argue that it is a more appropriate choice for the oil temps encountered. For track use GM runs M1 0w-40 in their own Corvette Program cars.
I don't pretend to be a Corvette expert but doesn't that vehicle have aluminum block/heads, dry sump, oil cooler, and engine cooling that could be described as heavy duty?
M1 recommends 0W-40 for the same car in the UK
M1 UK Corvette ZR-1
[/quote]Compared to a 10W-30 on start-up M1 0W-40 can be even lighter at temp's as high as room temperature. But make no mistake, compared to a 5W-30 like M1 it will be heavier at all temp's.
