Oh, and that dab of fresh oil around the gasket has to be mobil 1 or it won't work...
Quote:
You can now save that wrench for removing the filter only.
Quote:
It's nice to have all the manly types chime in and show off their testosterone. Not all filters are easily accessible by hand... and even if they are, I don't want to cramp my hand by getting the necessary 3/4 turn. I use a wrench. That's what tools are for.
Quote:
I don't even own a filter wrench. Turn them on as tight as I can without killing myself (usually about 3/4 - 1 turn after the gasket makes contact) and they always come off with about the same tension. Never had a filter come loose or leak, never needed an oil filter wrench or anything but my hand to take it off. Then again, I'm only fifteen years old, so probably not all that strong, hahaha.
Quote:
It's also the way I've always done it, and never had any issues at all.
