2000 Infiniti G20
Cleaned the throttle body with a throttle body cleaner from Valvoline. Sprayed it in, then wiped with a tooth brush. Now the car stutters for the first three or so accelerations in the morning. Then you feel like it opens up and goes back to normal. If it has been driven and warmed up, it runs fine. Do I need to clean it again? Any suggestions?
