It does? Anything to back that up? Making those kind of comments on a board like this will get you flamed fairly hard.
I'll back him up. I don't know much about oil I signed on to learn and have you experts correct me. That person and Pablo has helped me more then others getting started and from what I understand Teaelle is correct and this is why. First, I am open to all oil products. Second, I've got to know a successful engine builder who is very sharp in my opinion. His driver was experiencing high oil temps during races. The other well named product wasn't cutting it and he was losing POWER. He switched to 15w-50 Motul 300V. High oil temp is no longer an issue. This car is a Viper but his race cars are Corvette's and Farrari's. He said the oil temp now is good for the weekend before it wasn't. Motul 8100 5w-40 along with the 8100 line is a ester base oil. And it falls within new car warranties. I'm not an expert but I listen to experts including you folks and can tell when someone is piling the sludge. Here are the specs.
8100 X-cess 5W-40
Gasoline and Diesel engine oil
100% Synthetic
TYPE OF USE
Specifically designed for powerful and recent cars fitted with high displacement engines, gasoline,
Direct injection turbo Diesel and catalytic converters.
Numerous car maker approvals make this product multipurpose especially recommended when the
car is under warranty.
Suitable for leaded or unleaded gasoline, Diesel fuels and LPG.
PERFORMANCES
STANDARDS ACEA A3 / B3 / B4
APPROVALS API SL / CF VW 502 00 / 505 00 -BMW ‘Long Life-98’ -PORSCHE Mercedes Benz 229.3 -OPEL/GM Diesel LL B-025
* The OPEL/GM Diesel LL B-025 standard requires two main properties to the lubricant : high HTHS and very low volatility to drastically decrease oil consumption. Motul 8100 X-cess 5W-40 is especially recommended for OPEL 2.0 and 2.2 DTI engines (extended drain interval : computer on board).
* The ACEA B4 performance requires an outstanding detergent/dispersent power and a better viscosity increase resistance due to soot produced by Direct Injection Diesel engines (excep VW unit injector engines that require MOTUL Specific 505.01 5W-40)
* The MB 229.3 standard is more stringent than 229.1 in terms of ageing resistance (extended drain interval : computer on board ), detergent/dispersent power (ACEA B4) and requests fuel economy performance : 1.2% fuel economy improvement versus a 15W-40 reference.
RECOMMENDATION
Drain interval : refer to manufacturers’ recommendations and tune to your own use. MOTUL 8100 X-cess 5W-40 can be mixed with synthetic or mineral oils.
PROPERTIES
Viscosity grade SAE J 300 5W-40
Density at 15°C (59°F) ASTM D1298 0.854
Viscosity at 100°C (212°F) ASTM D445 14.0 mm²/s
Viscosity at 40°C (104°F) ASTM D445 83.1 mm²/s
Viscosity index ASTM D2270 173
Pour point ASTM D97 -39°C / -38°F
Flash point ASTM D92 228°C / 442°F
TBN ASTM D 2896 10.3 mg KOH/g
We retain the right to modify the general characteristics of our products in order to offer to our customers the latest technical development 3682
Product specifications are definitive from the order which is subject to our general conditions of sale and warranty. Made in FRANCE
MOTUL . 119 Bd Félix Faure - 93303 AUBERVILLIERS CEDEX - BP 94 – Tel : 33 1 48 11 70 00 – FAX : 33 1 48 33 28 79 – Site Web : www.motul.fr 09/02
8100 X-cess 5W-40
100% Synthetic
TYPE OF USE
PERFORMANCES
RECOMMENDATION
PROPERTIES
